Purchased an 80 Series as a family vehicle but who are we kidding? It won't stay stock for long (1 Viewer)
I am not sure my advice is sound....just another internet opinion. I wanted to jump in with both feet on the mods when I purchased mine but didn't have the funds at the time and didn't want to piece meal it together. I am glad that I waited because my needs have changed over the years and seen the regrets of people with overly lifted vehicles, roll overs, and scaling back of lifts and tire sizes. In the meantime while on the sidelines I have found out as many have preached that the 80 is a pretty capable vehicle stock. When I upgrade the suspension I am thinking high quality shocks with springs suited to my vehicles weight with minimal lift will suit my needs nicely. I don't wheel crazy but like to be off the beaten path and would like to have a dialed in suspension for comfort at moderate speed on dirt.
Also I am partial to the stock wheels. The allow wheels are strong and light, look good when cleaned up and the 16" rim gives more side wall for the tire. It may have less tire selection but I haven't had issues finding suitable tires for the 16 rims. I also like the stock steel rims with skinny tires but the rims are heavier than the alloy rims and haven't had issues with the allow rims yet so can't find a reason to change. There are some nice aftermarket rims too. The 300 series LC will have 6 lug pattern and larger rims and may have the right backspacing but haven't explored that as an option. Figured I may look at it down the road if I need larger brakes/calipers than can fit a 16 rim but I have kept my vehicles stock so far and the brakes work for what I have right now.
Houston
OK, so no mods have been done yet, but I have a weird issue I can't seem to figure out. I thought it was a dead battery, and I still need to get it tested, but it's a bit perplexing.
Usually it's overnight, but sometimes it will happen in the middle of the day, and just happened when I stopped for lunch and turned the truck off.
When I open the door and go to insert the key, I get all of the lights on the dash like normal, the chime of the key in ignition, and the battery gauge reads right in the middle if not a little higher than the middle. Go to turn the truck on, and it's like a completely dead battery. No click of the starter or anything, just straight up dead. If I then cycle the key to off, then to start again, same thing, completely dead. If I do it at least one more, sometime a few more times, it will then fire up and start and then the battery gauge reads around 3/4 up on the gauge.
I am making sure before I turn the truck off that I have turned off the radio, turned off the headlights, made sure wipers are off if they were on, and I have verified the dome light is off (as in I don't even have it set to turn on with the door opening). I also have been making sure I have the A/C turned off before I go to turn the key over.
My first thought is a battery on the way out. Maybe a starter that needs replacing. Anybody have any ideas?
Delta VS
Supporting Vendor
Boise, ID
Sounds like possibly the fusible link is on the fritz/bad connection? Typically the thing attached to positive post of your battery, couple/few wires to a little black plastic box. Easy to replace (should ALWAYS have two spares in the glove box) and not expensive.
Houston
Just purchased two from Wits End. If it's bad, I have a replacement, if not, I have two spares. I'll check the fusible link when I get home to see if I can spot anything fishy. Thanks!
Houston TX
I'd agree on 35's and 2-ish inches being the sweet spot .... Icon's are grea, t but have to say I'm happy with the OME's on this one so far for the $.....and my last 200 build had the Icon stage 5 setup with Tundra long travel kit on top....the solid axle limits the need for the CDC valving and long travel to an extent I think...although with the disconnects it flexes quite well, but slowly...
happy to meet up if you'd like to check out my rig and drive it.... it has many of the other things you're thinking of like 4x4 labs rear etc.... I'm out in Fulshear.
E
hood river oregon
Had this happen on my 91 & it was a relay. EFI relay if I remember right... ignition relay makes more sense but could be EFI relay cuts power to ignition if not engaged.
Just something to check...
