I'm tempted to ditch the rubber feet and just mount it directly to the the plate.
Otherwise to do it correctly, seems like you'd need three layers of rubber; top, middle and below the LCP plate. Thought about using bushings from the top of our radiators with that shouldered bolt, though that requires a decent sized hole being drilled through the Puma mounting legs...
Other idea was to use pieces of exhaust pipe mounting straps.
Or am I over thinking the amount of noise/vibration?
