Your FJ62 will have a LSPV (Load Sensing Proportioning Valve) in the rear of the truck that controls the amount of rear and front brake, based on the spatial relationship of the valve to the rear axle.
With you stating that you have recently rebuilt the front knuckles and replaced the rotors and brake pads, I am wondering if you bled the brakes, and if so, did you bleed the LSPV? The front brake circuit travels through this valve, and it has its own bleeder, and must be bled when the front circuit is bled. (iirc, it is to be bled first)
Many times with braking issues and the vehicle pulls one way, it is because the rear brakes are not working on one side, causing the vehicle to not brake squarely, and results in it drifting one way. Just because the wheel turns one way does not always mean that the brake problem is in the front.
What is the condition of your rear brakes? Does your parking brake work?
In order to keep the rear brakes properly adjusted, you must use the parking brake, as the rear brakes do not ‘automatically adjust’, unless you use the parking brake.
