My son and I safely removed the beast this past Saturday. Even with the motor mounts removed and the motor lowered, you need an offest 17mm to actually reach the upper bolts. I ended up doing one from above and the rest from below with a couple of long extensions, swivel and impact wrench. The bolt that gave me the the hardest time was the drivers side second from the top, what a biotch. Also the wire connection that runs along the top of the trans was a motherfuther as well.
Anyway, I ordered a main seal and oil pan gasket for my donor motor and will clean and install the motor this coming weekend.
What is the name of the motor in an 80?
Anyway, I ordered a main seal and oil pan gasket for my donor motor and will clean and install the motor this coming weekend. What is the name of the motor in an 80?
