Pulled Block drain & nothin...
Discussion in '40- & 55-Series Tech' started by Clutchee, Jul 1, 2005.
  1. Clutchee
    Clutchee I'm fun sized! SILVER Star
    3,843
    Media:
    16
    Albums:
    4
    885
    Apr 19, 2004
    Hotel M-F, home weekends!
    After help from JesterB & Euclid dads F motor was out. This evening I was removing items for a clean & paint on the block. Before removing the water pump wanted to remove the excess water from the block, removed drain fitting from lower drivers side of block & nothing. Look with a flash light & found black/gray shiny material hardened in its hole. With a ice pick I removed it....& more & more. Has any one heard or seen this before....maybe JB weld but why?
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,429
    Media:
    17
    Albums:
    1
    875
    Oct 1, 2003
    MN
    Been covered a bunch out here....You are not the only one to have found this substance in your block...clean it out the best you can, and run it.
    Good luck!
    -Steve
  3. mallred
    mallred
    616
    Apr 4, 2004
    My first thought is Radiator Sealer such as Bars leak or something like that, I would pull the soft plug check the whole system or if rebuilding, hot tank it.
  4. Clutchee
    3,843
    Media:
    16
    Albums:
    4
    885
    Apr 19, 2004
    Thanks for the quick replies.
    Would pulling the feeze plugs help this or will this area be accessable?
  5. honk
    honk
    3,413
    Media:
    10
    372
    Nov 14, 2004
    PNW
    As long as you've got everything stripped off why not pop out the freezeplugs so you can get an idea of how bad the stuff is spread around in the jacket. Might save yourself a clogged passage or radiator.
    If you do take out plugs be damned sure that you have the right size replacements. Compare directly - don't even trust your Toyota dealer to give you the right size.
  6. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    29
    Jan 3, 2003
    McCall, ID
    All of the Fs I've pulled apart had this stuff in the bottom. I found that removing the draincock and digging back with a screwdriver, then a stiff, bent wire was the way to get in, usually, although I pulled the head and dug from above once as well.
  7. Kief
    Kief
    5,351
    154
    Apr 24, 2003
    Southwest Oregon
    Definitely replace freeze plugs with factory plugs, the others are iffy, and very hard to get to. Trust me, I am speaking from experience. Use a wire and a hose to clean out all of the stop leak crud, access all the cooling areas from the vacated freeze plugs, if you pull the head that helps too. I have seen a motor that had been rebuilt and this junk had never been cleaned out.
  8. Bad Coco
    Bad Coco
    978
    258
    Dec 2, 2004
    Garden Valley, CA
    Try to replace them with the brass ones, not the shinny ones. Just my .02 :beer:
