I am rebuilding my PS pump. I am having difficulty removing the 17mm drive gear nut which is holding the gear drive that mounts inside engine block. The problem is trying to fix the gear so I can remove the 12 point nut. I made a wood clamp that hold the gear diameter but still slipping when applying force via socket wrench. I am assuming to unscrew its counter-clockwise…correct? Next thing to is impact it off, is this a good idea? Any suggestions
Thanks
Chris
Thanks
Chris
