Proportioning Valve Question
Knoxville
Several months ago I installed the OME medium load suspension that lifted the truck about 2.5''. When I did the install I wasn't sure about the proportioning valve and only adjusted it a few mm (to tell the truth I don't even remember how much). I've noticed since then there's been alot more brake dust collecting on my front wheels than in the back. Is this ordinary or should I adjust the valve a little more? Also if you've raised the rear of the truck about 2.5" about how much did you adjust the valve. Any help is much appreciated.
Matt
>> Also if you've raised the rear of the truck about 2.5" <<
>> about how much did you adjust the valve. <<
Lower the LSPV bracket a total of 1/4", but since you have no idea how much you've moved the LSPV this won't do you much good. See if you can tell where it was from the factory then adjust.
-B-
Thanks a ton, there's still a clear line of where it was from the factory so I will go from there.
More brake dust on the front wheels than on the back is normal. Comparing amounts of brake dust is not a good way to determine brake bias. :)
