NLXTACY
Wits' End
Even though I had the LX since new in 97, I didn't start monkeying with any kind of mods until 2008. Since then I have done many things to it but there has always been a HUGE project list that, for whatever reason, just seems to die on the vine. Some reasons:
• It could be from waiting on one project to make a decision on another.
• It could be that one project greatly impacts another.
• It could be that I over analyze the hell out of it.
• It could be because I wait for newer technology (think iPad vs. Mac Mini).
• It could be its so much money that my wife complains and I need her happy. (I just got her a 2014 IS-F Sport so this is becoming less of an issue)
• It could be that I am missing pieces.
• It could be that I have no researched enough into a particular mod that makes me comfortable enough to do it.
• It could be that I want to document it all to post on MUD but then it becomes a weekend project instead of a few hours so I put it off.
• It could be that its after store hours and I can't risk something happening and NOT having an auto parts store to go to.
• Etc etc etc.
So what I am going to do not is instead of listing the projects that I have finished, I want to detail the projects that I have yet to begin...for whatever reason. Please bear with me because the list is fairly big but I will post up as much detail as I can. The intent is to get the brain cogs turning to hopefully get feedback and other info so that I can go ahead and finally complete a given project. Of course this by no means a complete list, its just the list I currently have. What is not listed are things like armor, RTT and stuff that like. Those are obvious. I'm looking at projects:
• Power Steering
- Have bracket for new p/s reservoir made
- Mount new p/s reservoir
- Purchase new p/s pump to be port matched for gear box and hydraulic winch
- Have gear box rebuilt with 105 sector shaft and ported for winch
• Radiator
- New overflow tank made in aluminum
- Ron Davis radiator
- PrestoLok for overflow tank
- Switch/dimmer for hood light (in process)
- Install Coolant temp gauge (in process)
- Install Fumitomo valve, do I want to do this?
• Stereo
- Order amp and 8" woofer
- Mount rear fuse panel
- Route electrical cable to center console
- Order another large box of Dynamat
- Apply Dynamat to DS door
- Install vapor barriers
- Install Butyl Sealant Tape
- Replace front tweeter
• Hood
- NEW hood heat shield
• Install (4) 90980-11247 connectors to finish the signal wiring
• JDM200 horns 08522-60010
JDM 200 series Premium Horn install and sound comparison
• Misc
• Fix hand throttle
• Work on Fuel Filter mod
Remote Fuel Filter set up or kit
• Potable water hose NOT rubber hose for OBS (3/8" I.D.)
• Replace interior lights with LED
• Charcoal Canister- Replace with new
• S/C
- Purchase Banjo T-clamps
- http://tinyurl.com/l3ztso9
- Install 2.8 pulley AFTER installing InterCooler
- Install manifold pressure/boost gauge
- install EGT/Pyrometer gauge 3344
- install wide-band O2 sensorAFR gauge AEM 30-4100
- Intercooler
Water to Air Intercooler Kit for the TRD Supercharged FZJ80 Land Cruiser
- Install Transgo shift kit
- TransGo Performance Shift Kits 340-HD2
- Purchase and install manual torque converter lockup
- West Coast Cruisers
• Front bumper
- Route hose from tank to air manifold
- Add lights with locking nuts
- Have bumper powder coated/painted
- Add hook for hammock
- Attach steps
- Mount limb riser tabs
- Mount the 21" LED light bar
- Install block heater
- Install Gen2 charger
• Fridge
- Hardwire to DC
- Decide if I want to use the hinge flip kit
- Find a wireless thermometer
• Mirrors
-Purchase mirror heating elements
-Install mirror heaters
- Install the heater switch
- Purchase side marker blinkers
- Install blinkers
-Mount mirrors
- Mount exterior temp gauge on DS
-Mount CB antenna on PS
• Leather
- Order new airbag cover
- Order new shifter leather
- http://tinyurl.com/lyx47le
• Camping
- Storm case for Partner steel and cooking kit
- Get the carrying case for it:
2 Burner Partner Steel Stove Bag 18
- Partner steel stove
Kanz Outdoors
- Hard mount the propane tank
http://www.kanzoutdoors.com/product55.html
- Disposable tank adapter
http://www.kanzoutdoors.com/product44.html
- Find permanent camping cups (plastic sucks)
http://www.expeditionexchange.com/snowpeak/
- Kovea LPG Adapter
http://www.expeditionexchange.com/kovea/
• Lift
- Install DIY Panhard kits for front and rear
- Replace OEM bushings
- cut out 4" section on both and weld in place
-Make a small bracket for the e-brake to raise it on the diff side
- Install brake gauge
- Install front bump stops
- Install new rear LCA bolt/washer/nut (frame side)
• Wilson Cell Phone Booster
http://www.wilsonelectronics.com/store/display/9/38/mobile-3g
• Closed container for the fuel siphon to prevent fuel smell in cab. Freezer bag?
• 3M Plastic Polish for the cluster
http://www.amazon.com/dp/B0002U268M/?tag=ihco-20
• 3M Finesse for black trim
http://www.amazon.com/dp/B0009KJ21O/?tag=ihco-20
• Anodize the rear license plate mount
• Purchase new Yellowbox v5
Official home page of the Yellow Box Speedo Recalibrator
• Butane torch for the truck
• HAM radio
• Fix the JDM fan. Is it a voltage issue?
• Finish the misters project
• Install my CB
• install rear view and front view cameras
• Etc etc etc.
• Power Steering
• Radiator
• Stereo
• Hood
• Misc
• Fix hand throttle
• S/C
- Intercooler
• Front bumper
- Attach steps
• Fridge
- Hardwire to DC
• Mirrors
- Install blinkers
• Leather
• Camping
Kanz Outdoors
- Kovea LPG Adapter
• Lift
• HAM radio
• Install my CB
