14H8 what means 14,027mm H8 ist the tolerance class. You pair tolerance classes for fits according to the use. For example, if I want to mount a bearing on a shaft, I need an interference fit, and if a shaft is to run in a plain bearing, I need a clearance fit. (No guarantee that certain technical terms have been translated incorrectly by me here).If I'm understanding correctly, you had a 13.95mm shaft sliding in a 14.00mm bore and it bound up? Opening the bore up to 14.5mm allowed the shaft to move correctly and not bind? .55mm seems like a lot of clearance, but can't argue with success.
Yes - my 1986 FJ60 has manual cable driven front and rear lockers. Not very smooth but they work and have for 35 years.Super interested also—not having to rebuild the factory motor (again) sounds amazing.
It's a different concern entirely, but some of the early trucks (60 series, 70 series, probably more) had factory cable lockers. Combining some of those factory interior parts with your cabling and housing could make for a fun retrofit.
