Second time giving this a go and it still didn't work so I'm a little frustrated and looking for some help here.
I'm trying to isolate some driveline noise by process of elimination, so I'm trying to drive without the front shaft to test. I've read up from what people say here and basically you need to engage the CDL then pull the shaft.
Well this is my second go around; Turned on the truck, engaged the CDL, pulled forward up the drive way then backed out a bit, then threw it in neutral, pulled the front driveshaft.
When I try to put the car into gear without the front shaft the CDL just clicks. What am I doing wrong here, am I not getting full lockout before I'm pulling the shaft? What is the full procedure I should follow with the CDL switch?
