Problems with OME 2.5" Lift
Discussion in '80-Series Tech' started by 80 Cruiser Rod, Mar 3, 2007.
  1. 80 Cruiser Rod
    80 Cruiser Rod
    733
    Media:
    6
    Albums:
    1
    12
    Jan 29, 2007
    S. Jersey - New Germany
    I just had a 2.5" OME standard lift kit installed. I know that there is a settling in time. After the springs and shocks were installed I was told that there was no need for an alignment because the steering wheel was straight and there wasn't any pulling while driving straight. So in the interim the caster correction kit was not used. I was told to drive it for about two weeks and if there was a problem to bring it back.
    Now, I just measured each wheel well and there are no two alike. From the lowest to the tallest there is as much as a two inch difference. I asked if there was a chance that the springs could have been mixed up and the answer was no. I was also told that when the springs where sitting on his bench they were the same size in height.
    Is all this normal?
    One thing I have to say is that my rig has a much nicer ride now. Also, I did measure all of the wheel wells just before I had the kit installed and they all measured the same. I was surprised when I saw that.
  2. Romer
    Romer fatherofdaughterofromer Moderator
    10,815
    2,041
    Sep 14, 2003
    Centennial, Colorado
    The springs are not the same hight. One spring is longer than the other and needs to go on the side with the longer axle (Bigger distance from diff the wheel). It is not two inches longer though.
  3. spressomon
    spressomon glutton Moderator
    12,526
    Media:
    13
    Albums:
    1
    1,091
    Jan 9, 2005
    Northern Nevada
    About 15mm if memory serves me correctly.
  4. tech_dog
    tech_dog
    1,146
    6
    Jan 12, 2006
    San Diego
    If your two inch difference is front to back, then it probably isn't a problem. If it's two inches side to side, then something is wrong.
    You should definitely get the castor correcting bushings, as your emergency handling will suck without them.
  5. Skim
    Skim
    887
    Oct 4, 2004
    Benicia, CA
    Make sure you tire pressures are the same.
    If you measure from the fender to the ground you are including the tires, and therefore including the actual tire height- and that changes based on tire pressure.
    Look in the FSM and see how to properly measure the ride height, the way described does not include tire diameter.
  6. reffug
    reffug
    3,925
    10
    May 28, 2004
    'in dat der briar patch'
    He be right except the hight part.
    Where I come from its height.
  7. alaskacruiser
    alaskacruiser
    1,619
    21
    Mar 30, 2003
    LA, CA
    He is right except the "its" part.
    Where I come from it's "it's".
    :flipoff2:
  8. MoJ
    MoJ Moderator
    3,575
    482
    Oct 24, 2003
    What he said.
    You'll see a height variation front to back normally.
    If they got the springs on the wrong sides on both axles than the greatest difference in height will be between the driver's front and passenger rear.
    You used to be able to verify the springs are on the correct side by simply looking at the tag on them. Anymore I'm not clear thats the case.
  9. reffug
    reffug
    3,925
    10
    May 28, 2004
    :doh:
  10. landtank
    landtank SILVER Star
    19,227
    1,493
    Mar 27, 2003
    Groveland MA
    What kind of numb nut evaluates the alignment after a lift by how straight the steering wheel is?
    You need to install the bushings.
  11. pbr streetgang
    pbr streetgang Supporting Vendor SILVER Star
    1,357
    361
    Nov 3, 2006
    AZ
    Slee's website explains which spring is for which side.
    Good luck.
  12. L8Shift
    L8Shift
    189
    22
    Nov 1, 2005
    Fairfax, VA
    I have the taller spring on the longer axle side and used 30mm spring spacers to balance left to right. hmm
    As for centering the steering wheel (after an alignment), I end up tweaking that out myself on the road.
  13. 80 Cruiser Rod
    80 Cruiser Rod
    733
    Media:
    6
    Albums:
    1
    12
    Jan 29, 2007
    I apologize for the delayed response to all or your answers. We had our annual game dinner at my Gun Club this weekend. It's a 2 day event with a lot of preparation for our sunday dinner. I definitely appreciate all the advice. Tomorrow I will post the exact measurements of difference between all of the wheels.
    Thanx :grinpimp:
  14. 80 Cruiser Rod
    80 Cruiser Rod
    733
    Media:
    6
    Albums:
    1
    12
    Jan 29, 2007
    OK here are the measurements taken from the center of each wheel.
    LF———————RF
    35.5" . . . . . . 36.5"______1" difference
    LR———————RR
    37" . . . . . . . 37.5"______.5" difference
    Now the mechanic is not familiar with LCs and he is the only one I could find to install this Lift kit. I will go back to him and have him install the Caster correction kit. Would this have anything to do with the unevenness of the vehicle?
  15. Nay
    Nay
    4,745
    785
    Aug 17, 2004
    Colorado
    Caster correction won't make a difference to the L/R lift heights. Fronts coils need to be swapped. Not sure about the rears, because the taller RF will give a compressed reading on the LR, so you need to do the fronts first and then remeasure.
  16. Lugboot
    Lugboot
    1,289
    Media:
    6
    Albums:
    1
    7
    Oct 19, 2006
    Pennsyltucky
    I had the same issue with my truck--it sat lower on the left side. The spring tagged "A" was on the left and had to be swapped to the right. After swapping the front springs, the truck sits level. The front springs affected the rear stance as well, meaning it was down in the rear left due to the front springs being backwards.
    My understanding from Slee is the OME kits have instructions for Australian DS and PS and some people here put the springs in US DS and PS when in reality, that results in a backwards install.
    Here's my thread on the same problem:
    https://forum.ih8mud.com/showthread.php?t=131926
    Hope this helps.
  17. NorCalDoug
    NorCalDoug problems solved daily...
    6,293
    115
    Oct 27, 2003
    uhhhh...duh...Northern CA
    the taller of the two springs goes on the left side of the rig.
  18. 80 Cruiser Rod
    80 Cruiser Rod
    733
    Media:
    6
    Albums:
    1
    12
    Jan 29, 2007
    Makes a lot of sense, I'll have him switch the front springs and go from there.
    Thanks again
  19. 80 Cruiser Rod
    80 Cruiser Rod
    733
    Media:
    6
    Albums:
    1
    12
    Jan 29, 2007
    Ok, I swapped the front springs and had the CC bushings put in. I'm glad I had the chance to drive my rig w/o the CC bushings because there is definitely a difference. One thing I noticed is the truck doesn't feel top heavy when evasively turning the wheel while going straight. I guess the handling is back to or close to OEM specs. Thanks for all the help mud, I definitely made the right decision.:beer: :beer: :beer:
  20. XXXR
    XXXR
    222
    May 1, 2003
    Santa Cruz, California
    Always check Slee's site for tech... Christo has done such a great job detailing the step by steps, it is a default for me when working on the 80. I'm sure you would have caught the spring swap immediately.
