Bought the 80 used and the owner didnt have the remotes for the alarm system.
It's a factory TVSS. I bought a new remote from Cdan and followed the instructions in my TVSS user manual.
I erased the existing ID Code by turning the key to the ACC position and then pressed the progamming switch for 2 seconds on the main alarm control unit. The alarm LED lit up and I pressed the switch again. This caused the horn to sound twice and the LED went off. This verifies the proper erasing of the existing code.
To program a new code is pretty much the same. Turn key to ACC position. Press programming switch for 2 seconds and while the alarm LED lights up, Im supposed to press the new remote once. I did this but nothing happens.
Any thoughts?
Once bit of info, the antenna wire connector on the alarm control unit was disconnected. I reconnected it before starting the above steps.
Any thoughts?
