I recently got the AHC removed and Got the Slee Heavy OME 2.5" kit installed.
Mine is 2001 , LX 470 with 180K miles.
Just one week after the install, one day when returning from Lowes I suddenly had some slipping and then suddenly the steering started getting locked, to top it all power to the drive was lost (more gas pedal did not move the car).
On the Dash the following lights came on "Battery" , "Check Engine" , "A/T Temp" , all the other temperature gauges reported normal.
After sitting and idling for some time, I switched it off and then turned on. I was able to drive for couple of hundred yards(to my driveway ) and then the problem returned.
So, I got the car towed to the best Transmission shop I know, thinking it had something to do with the transmission. Three weeks later with the shop, they could not replicate the issue. Full checks of transmission were performed and no issues were found.
So I got the car back from the transmission shop and started driving it regularly to work ahoping for the best. After one week the problem returned again this time in rush hour traffic. Luckily it happened 100 yards from my regular toyota mechanic(who did the lift upgrade). The car is parked there and they have had spent some time on it trying to diagnose the issue.
So I wanted to check with fellow mudders... for some help with diagnosis
Below are some observations from when the lights come on...
- Engine idling, no power to the pedals
- Steering is locked
- Battery, Check Engine, A/T Temp lights on
- Temp gauge shows normal
- Switching off the car and starting on, makes the lights go away and the vehicle becomes drivable again
- Coolant levels look normal
- Steering fluid level looks normal
- No Codes were found !!!!
What could the problem be, my guess is the wrong fuses for AHC were removed. Any ideas?
