At 108k miles, I had my trusty mechanic replace the front rotors with new OEM ones from cdan. He also installed the 100-series brake pads from cdan without any problems. Everything worked great for a little over 42k miles.
Today at over 151k miles, I had the same trusty mechanic replace the front pads with 100-series pads that I got from cdan. The rotors are still in great shape, so no new rotors.This time, my trusty mechanic told me that he couldn't fit the inner brake pads on the right side (passenger side). He had to mock around with the shim to get the inner pad to fit. Now the inner and outer pads are centered.
He also bled the brake fluid, so I have clean brake fluid. Unfortunately, the brakes seem to take a lot longer to brake. I was on the freeway and traffic stopped suddenly and I was worried that I wasn't going to stop in time. This didn't happen before. The brakes don't respond as good as before.
I'm not sure what might be wrong, but I'm a little worried. Why do I have to press on the brake pedal a lot harder to get the 80 to stop in what appears to be a much longer distance?
Today I also replaced all the stock springs and shocks. In the front, I have the OME 850 springs and the N73 shocks. In the rear, I have the OME 860 springs and the N74E shocks. Replaced steering damper with OME SD24 and caster bushings with OME CA77B. I didn't think that getting a lift would affect the brakes at all.
I'm going to the mountains this weekend to backpack with the Boy Scouts, but I'm a little worried about my brakes. Any ideas on what might be wrong?
