I wasn’t happy with the pedal feel and did a bleed of the fluid. Sure enough there was air coming from the front calipers.
While I could do the rear passenger side without issue, the rear driver side had no fluid at the bleed nipple.
However, clearly it is braking as the disc is hot after running.
Do i need techstream to open some valves ?
Is there anything I did wrong
After the bleed the braking is good with firm pedal. Master cylinder was changed 18 months ago.
