Perhaps I'm not recalling correctly - obviously, it turns in the same direction as the distributor.
View attachment 1577125 View attachment 1577124
So here’s my pictures of my old cam. There are a couple of holes in the cam that line up to allow oil to flow up into the rockers. So this means that both 10 & 11 rockers when fully open line up to allow oil to flow to the rockers. 1 & 2 might do it as well but my cam was broken so I can’t tell tell how those ones might be aligned.
Are you saying I should see the oil pressure go up on the dash gauge? I can feel some extra resistance whenever I turn it with the drill, however the gauge, I'm told by my daughter, does not move.I’ve never had trouble getting oil to trickle from the rocker oil holes, while spinning with a drill.
But, it seems others have had trouble getting oil to the rockers, due to the dissy out by 180*, or the head gasket on wrong.
You should be seeing oil pressure, at a minimum, while spinning...if your oil pump isn’t dead.
With the dissy seated, try rotating the dissy 180*, then pull the dissy and spin the oil pump again.
There are more links at the top of THIS
