I am getting ready to start up my 69 FJ40 with a new 2F rebuild and I want to be safe.
I have primed the oil with a drill in the dizzy for a few minutes but I still don't get any oil up to the rocker arms.
An SOR tech and someone from this group said you won't see oil on the rockers until the cam shaft is moving. So I ran the starter for a while and the cam moved and the valves went up and down but still no oil to the rockers. I can't run for too long or I will lose my battery charge.
Should I lube up the rocker arms manually and then try to start it up and run for a few minutes to see if the oil is getting to the rocker arms? Or is there another trick I can use to prime the oil up there before I try to start it.
When I put the rocker arm back together after cleaning it I was careful to align the intake hole in the rocker arm shaft to the oil intake rocker arm pedestal. But I guess its possible for it to have moved slightly. How can I tell if this is still aligned? To me it seemed like a very hokey design.
Thanking you in advance for your help. Also, I live in Simi Valley, CA. If anyone wants to come over and help birth the new motor.
