Pressing rear wheel bearings
Discussion in '40- & 55-Series Tech' started by sorenoneill, Aug 12, 2005.
  1. sorenoneill
    sorenoneill
    29
    Media:
    2
    Albums:
    1
    Oct 30, 2004
    Scottsdale, AZ
    Hi all,
    Does anyone know the easiest way to press wheel bearings and oil seals into the rear axle of a 40, without the hammering.
    Thanks.
  2. stinkyfj60
    stinkyfj60
    1,344
    3,384
    Apr 22, 2004
    Roodepoort, South Africa
    Just the hammering. I used a block of wood to get the them in, to do it straight and not beat on them. Then used a brass drift to finish them off.
  3. FLFJ40
    FLFJ40
    271
    Jun 11, 2004
    Jacksonville, FL
  4. 65swb45
    65swb45 Elder Statesman Supporting Vendor
    24,349
    9,361
    Apr 14, 2004
    818-953-9230
    I welded a 1/4 steel plate across the race of an old axle bearing race and voila, a SST!
