I've had my '94 LC for almost two months now and really haven't had time or the knowledge to baseline the car for maintenance. And I want to take it on some distance drives with fam to the mountains 3 or so hrs away and don't want to break down.
Engine has been rebuilt by PO about 12k miles ago but drivetrain has some intermittent noises.
Car would give a whirring groan at hwy speed occasionally when letting off throttle. I couldn't determine where but it was in the front- diff, wheel bearing or drive shaft I assume.
I inspected the shaft and there wasn't any play but gave it a cpl shots of grease for good measure. The sound would still happen, again only intermittently and not easily replicated. So I removed the front driveshaft and fuse locked the diff (no CDL). Sound hasn't returned but a fainter softer groan could be heard even less frequently. Typically while the noise would only last a few seconds it would go away on load- hwy speed again- never at city speed.
Wheel has a small amount of play when shaking only if jacked off the ground. Solid with car not jacked. I'm too noob right now to do wheel bearings but wondering if it's the diff or TC too. I have supplies to do the oil soon and thought might as well do diff and TC fluids too.
Salt on wound, the AC is coming and going now too- mostly works after a 2 second devil shreak- i got new belts but current look good.
I want to get this rig solid for long distance travel without stranding with 3 and 5 yr old girls.
Any ideas from the pros? Any other travel items I should be aware of? Pic for attention.
