cut a round plate with a diameter similar to the bearing cone, from a 0.15 mm tin sheet. install that plate then press the cone.. you'll need to use thinner preload shims"a very thin metal plate under the trunnion bearings--- we do the same to the 80s and other vehicles with similar setups at our shop"
@blinkerfluid :
How is this done in the 80 series??
Do you have photos you can post up?
I'll dig a picture or take some on the next job.. this is a diagram from the Nissan fsm for an idea
