Premature trunion bearing wear
"a very thin metal plate under the trunnion bearings--- we do the same to the 80s and other vehicles with similar setups at our shop"
@blinkerfluid :
How is this done in the 80 series??
Do you have photos you can post up?
cut a round plate with a diameter similar to the bearing cone, from a 0.15 mm tin sheet. install that plate then press the cone.. you'll need to use thinner preload shims
I'll dig a picture or take some on the next job.. this is a diagram from the Nissan fsm for an idea
So the thin sheet of metal (? custom kingpin plug) is installed before the bearing race for the top trunnion bearing, then the race, then the bearing.
Would also help if you could post up a photo of the Nissan plug or plate
and/or the Nissan part number.
heres a link
Nissan P/n 40040-01J00
its basically a metal sheet cut in a circle and coated with rubber,
