jblueridge
On Sunday I noticed my dash volt meter was reading low right after I started the truck.
It showed low for 3 or 4 minutes, then jumped up to normal.
It was the pre-heater system drawing power, but the Pre-Heater light does not come on.
Yesterday I checked the water temp sensor and it showed a sensible 3K ohms.
That is within spec.
I disconnected the wires that feed the pre-heater's toaster wires.
When I started the truck the volt meter showed normal, and the pre-heater light came on and stayed on.
Reading the manual, the light staying on informs the driver there is a problem with the system... so that is working properly.
With the FSM I will continue to do tests when I get time.
I am wondering if anyone has run across this before.
