86aggie
I'm trying to isolate the issue of the passenger side windows and rear driver window not working via switches.
1. Front driver works with no issue.
2. Rear driver works with jumper wires, and intermittently with switch(driver panel or door)
3. Front passenger does not work with either switch
4. Rear Passenger does not work with either switch or jumper. Works with direct power from battery. Measures 12v+ at switch connector plug, but doesnt work with jumper to motor.
I'm thinking it could be:
1. Fusible link
2. Relay in driver door
3. Bad Ground
Any suggestions, besides the rewire the entire power setup with new relays?
1. Fusible link
3. Bad Ground
