power to manual antenna replacement parts?
tejas
can anyone tell me if there is another part number i need to remove the power antenna and replace it with a manual one?
i have part number 86300-60030 but i’m wondering if i need another part.
THANKS
1902076
Jersey, 07740
that should be all you need, besides obviously needing an antenna mast. might need a little work to get it to mount perfectly vertical but if you don't care that it may be on an angle than its just bolt it up and go
tejas
It looks like that comes with mast unless i am not seeing correctly.
thanks. i actually ended up buying it on ebay since CY was out of stock when i finally got around to pulling the trigger. part number was correct but it looked like it was missing the mast. i guess it’s a totally separate part that you have to insert? and i’ll just find out if they included it...
