Truck is a 1986 FJ60. My dome light and carb cooling fan are not working. At the fuse box, there is no power to the "Dome" circuit when the ignition is in the "Off" and "Acc" position. Once the key is moved to the "On" position (truck does not have to be running), I get power (12V) to the "Dome" circuit and the dome light.
I have searched different threads and tried everything I know to try. I've cleaned the common ground on the 3rd cross member, taken apart and cleaned the "Cooling Fan" relay, changed out all the fuses. Any ideas where I should look next?
Thank you in advance for the help and guidance.
