power steering pulley (1 Viewer)
biloxi ms
Sorry to post this twice! I posted on the 90 series incorrectly...
Need advice on removing the power steering pump pulley on my 2004 LX470. No bolt securing the pulley to the shaft???
Rebuilding pump and I need to get to the shaft seal and I just don't want to cause any damage.
Thanks for any help in advance!
I tried removing the pulley when I was replacing my tensioner assembly, but didn't see a way to remove it. I pried on it a bit thinking it would slide out, but realized that wasn't going to work. I was confused because I had seen others have a securing nut, but mine didn't (on a 2006 LX470). Later I saw a youtube vide where newer models don't have that securing nut. So I ended up removing the mounting bolts for the power steering pump instead and moved the pump to the side so I could continue to replace the tensioner assembly. Sorry I don't know if that helps you or not. Maybe someone else can chime in
