Hi all, I have a pretty big leak coming from the top of my power steering pressure tube from almost where it enters the reservoir. Would I need to replace the whole line or can parts of it be removed/replaced? It's been tricky trying to find info on this part.
The fluid is leaking from around where the rubber cover (under the foam) meets the exposed braided tube (which I'm assuming is normally covered as well, mine looks damaged). It's essentially seeping out at a fairly consistent rate.
Thanks!
Thanks!
