Power steering line--Help
Discussion in '40- & 55-Series Tech' started by vtcruiser60, Mar 17, 2004.
  1. vtcruiser60
    vtcruiser60 SILVER Star
    2,558
    2
    Sep 23, 2003
    I don't want to get hosed, literally.
    RE: 92 FJ80, 131K
    The high pressure steel lines for my power steering have rusted and are leaking below the radiator. The unit is sold in two parts from the dealer and I have been quoted, $400. I found used lines from cruiserparts.net for $200. Each option sounds expensive to me for simple steel high pressure lines.
    Can I use braided steel lines? Can I simply flare some brake line and use it instead? Come on, there has to be a cheap solution here.
    -KMK in Vermont
  2. wesintl
    wesintl
    4,520
    Media:
    1
    Albums:
    1
    34
    Mar 14, 2003
    Between Here and There
    That is basically a cooler for the PS as well. You can either bypass it with a home made Napa style adding in your own cooler. You could by a pressure line from advance autoparts for $120, or NAPA for $99.
    HTH
  3. Landpimp
    Landpimp GOLD Star
    15,929
    Media:
    1
    1,951
    Mar 14, 2003
    Gig Harbor WA
    I was thinking the same thing that it was the low presure cooler tube(like a 40,60/2), but on a fj80 I think both the high presure and return line(cooler) are metal pipes, you solution would work great for the low presure/return/cooler but not sure about if its the high presure line.
  4. wesintl
    wesintl
    4,520
    Media:
    1
    Albums:
    1
    34
    Mar 14, 2003
    It is a high pressure line. The pump on a 3fe is on the passenger side. The box is on the driver frame rail. I run a 3fe pump on my 2f 40 in the same location with a 60 box. I just went to a hydro shop and had a soft line made that basically follows the same as a 62. I figuered it be less than $100... well it wasn't but I was still happy. Your right about my comment about the cooler.. OEM does run the same type of line back to the pump for low pressure. That's where I think i was thinking about the cooler.
  5. Isotel
    Isotel
    4,061
    Media:
    5
    Albums:
    1
    39
    Sep 29, 2003
    Crawlorado.com
    you may be able to have a shop make one for you for cheeper.. i would do just about anything before i paid $400... and i cant belive you have rust on a 92'
  6. Pin_Head
    Pin_Head
    14,578
    2,208
    Feb 6, 2002
    OC, CA
    Have your local hydraulic shop make one up for you. They can make anything as long as you bring the old one in. The dealer wanted $600 for the hoses on my wife's Infiniti and the local shop made them up for $60.
