power steering hose change???
hey ya'll. looking for some advise on how to best change out my high pressure, power steering line on my 94 fj 80. its the one that makes a sharp u bend. dan's got the part on order for me, regretably - i can't recall its exact name. is it necessary to bleed the entire line, once the new hose is in? don't want to leave a trail of ps fluid all the way to mexico! :o ya know? thanks - vic
Sheddy...did you replace/rebuild the PS pump? My 94 is starting to moan. Curious if you bought a rebuilt/new or changed out another used pump. Planning to rebuild mine in nov.
Thanks
Chris
chris, i've just got a leaky hose. no moaning here in flagstaff.... i hadn't planned on a rebuild, just replacing the bad hoses..
also, thanks for mentioning the low pressure hose change out.. vic
If your pump is moaning, consider a flush before rebuilding. The additives are trashed long ago if it's original fluid, which allows it to cavitate. Takes all of 20 minutes, and will cost ya less than $10.
Doug (with newly silent pump)
