Hello all, I purchased an 82' FJ40 which was imported from Venezuela, and I'm SLOWLY getting it road worthy. I need some advice on how to get a rebuild kit for the PS gearbox, or best options for getting this one rebuilt. Any suggestions?
Great question, and one I hadn't considered enough, until now, even though there's enough other stuff I've run into that wasn't original. You'd think I'd have thought of that. After further inspection, the pedestal is cast iron, but has been welded onto the frame, and it looks like I can see a bolt hole from a previous mounting that is no longer used. I'm including pics of what I have. This may explain why there is some sheet metal bent away from the area the pitman arm is located.Have you compared it to pictures of stock 40 series? Is the system stock? Is the pedestal cast steel?
I cannot help you; my plate is full (see signature line)By the way, after inspecting the shafts, namely the pitman arm shaft, it has significant wear, to the point of needing to be replaced. So, a rebuilt unit may be my best option.
