Power Steering fluid issue HDJ80 LC
dml
W. Africa
Hey all, I have a 92' HDJ80 LC and recently have had power steering fluid exiting the reservoir. Mechanic said it was a bad pump...changed the pump and same issues. Frothy fluid, definitely air in the line and sprays out the top when in use. Anyone run across the same problem, what did you do? If it's as easy as bleeding the lines, how do I do it properly? Thanks!
