Power steering conversion recommendation for 67 FJ40 with V8 conversion (4 Viewers)
Colorado
Power steering conversion recommendation for 67 FJ40 with V8 conversion needed. I have a Gen 3 V8 conversion and running 35" tires. Its a standard V8 conversion, but with the larger tires, its tiring to turn. Any PS conversion kits or tips are appreciated
DangerNoodle
Essentially a fire wielding monkey.
Divide, Colorado
4x4 Labs Sagniaw Conversion is probably the best available. You can pick up a 4 Bolt Saginaw box from a lot of places, but I personally would recommend a 4+ turn box for your setup. Some people hate them but I really like them.
Southern Colorado
2nd on the 4 turn box for good control and lack of twitchyness. You may be able to get a reman from Rock Auto for the appropriate GM product.
pb4ugo
spay-lay-wi-theepi, Ohio
I'd recommend scout/fj60/80 steering. It's an easier and cleaner install and less evasive on the frame. I'm running a Scout box. They are getting scarce though.
pb4ugo
Just curious, how much cutting/ altering of the fender is needed for the 60/80 conversion?
I had to do my 1s scout conversion because the po hacked the frame rail so much I had to install a new frt crossmember and scab the left frame rail. The stress on the frame was pretty significant. In that conversion I just cut out the necessary sheet metal on the inner fender well to clearance for the box. Its still looks better than having the sag box out frt. On my 2nd conversion I didnt want to cut my new OEM fenders so I altered them.
Vae Victus
Posting more than I know
Nashville, TN
I'll be bold and conditionally "suggest"* City Racer's @Racer65 electric steering setup. Much less intrusive, faster setup, but suitable for on road and light off road use only - not suitable for tires bigger than 35" or heavy wheeling.
*I cannot yet officially recommend as I've not installed yet, so YMMV.
Riverton, Wyoming
I am planning on using the FJ80 steering box for my restomod bo my 78.
pb4ugo
I would like to see more info on the FJ80 steering box conversion along w some detail pics and how to steps. @Well Sorted said they use an 80 box with a 60 Pitman arm.
You can look in the faq's and scroll down to steering or go to the tech links in the same section. Also use the search function and search scout and fj60 steering. The setups in principle are the same as it would be for the fj80 box. Everybody does it slightly different, whether your altering or moving the stk shock tower or adapting the ford tower, or scabing the outside of the frame or not.
Colorado
Im lookimg now at the 4x4 Saginaw. What year/model 4 bolt steering box and pump should I be looking for? Remember, Ill be asking a counter person for the box..........
Colorado
So what is a "4 turn box" Imagine you are parts counter person: I need as much part info as I can get to relay to the parts folks
