gents.
i ordered the gamviti gears because i imagine i will have to do them at some point.
also - at the moment the DS power switch will only cause the driver's seat to move /forward/ and not allow it to slide backward. i found this thread and THIS post from @JohnVee appears to be the symptoms.
"My passenger seat Forward/Back slider switch would get hung up instead of returning to center after moving forward. The motor would stop when I let go but the switch was still forward, so if I moved the switch backwards I might only have moved it to the center/off position. Point being I wasn't actually moving it far enough rearward to activate the motor. Some contact cleaner took care of it and the switch slides well now. That seat doesn't get used often so the controls can gum up. This is likely not your issue but it's worthy of a mention."
(Gamiviti seat gears, the aftermath !)
does anyone happen to know what i am cleaning up when i get in there? and do i have to pull the whole seat or can i get at this fix without pulling the seat? meaning can i fix an issue like the seat not moving backward by getting at the switch from the side? or do i need to pull the whole seat? i'd prefer to fix the sliding issue now and do the full gear R&R this summer when it is warmer out.
i do have the gamviti instruction from @nakman here:
http://forum.ih8mud.com/80-series-tech/236037-front-seat-gear-swap-broken-seat- missing-cap-issue-pt-2-a.html
anyone able to advise or point to a thread that shows and R&R of the switches?
THANKS
THANKS
