power loss 1HZ
Discussion in 'Diesel Tech / 24 volts' started by tom bakkum, Nov 6, 2005.
  1. tom bakkum
    tom bakkum
    3
    Nov 6, 2005
    The Mud
    Problem with my 1HZ engine, ever since I bought a few years ago. Speed is just too low, a topspeed of 110km/h. It is not smoking, it does accelerate quite normal, but uphill and highways are just a nightmare.
    The symptoms do not seem to change over the past couple of years.
    Could the pump be defective?
    Is there a tiny little filter somewhere between the pump and the main fuelfilter?
    Any other suggestion?
    Please note that I am located in Kenya where no decent workshop is to be found…
    tom.bakkum@gmail.com
  2. semlin
    semlin discouraged user
    5,248
    Media:
    1
    Albums:
    1
    2,134
    Mar 27, 2003
    north of 49
    welcome Tom, you need to post your question to the international cruiser forum here at mud. a few doors down on your left. :D most people in the 80 section have gasser 80s and the international guys are the true diesel heads.
  3. neowulf
    neowulf
    126
    Jan 30, 2005
    Norway
    adjusted you're cam chaft timing / clearance ?
  4. Stone
    Stone Moderator
    3,130
    10
    May 13, 2004
    BC, Canada
    Wayne...I copied your reply to this thread from the duplicate one so that I can erase the other. Hope you don't mind.
  5. roscoFJ73
    roscoFJ73
    16,017
    Media:
    3
    Albums:
    1
    1,944
    Jul 22, 2003
    Perth Western Australia
    How many klms on the pump and engine? The pumps on these often need rebuilds between 2-300000klm.
    They seem ok when cold but as they heat up they lose pressure.
    There is no filter between main filter and pump but maybe you have a crushed or kinked fuel line.
  6. beanz2
    beanz2 Moderator
    2,126
    7
    Nov 16, 2002
    Have you compared the power with another 1HZ cruiser? They should run decently well. With poor fuel quality, the injectors can wear rapidly. Pull them and send them to have them checked at a diesel shop.
    Dave
  7. VTCruiser
    VTCruiser
    3,475
    36
    Sep 12, 2003
    Tacoma, WA
    only 110km? something has to be wrong, the 1hz in my 60 will do 80mph (~130km/h) all day long, but really that's faster than i need to be going...
  8. -uhuru-
    -uhuru-
    197
    Media:
    3
    9
    Aug 9, 2005
    Panama
    Hi Tom,
    I think I met you in Panama ... we talked about a tire carrier I had built for my 80 ... guess you´re back in Kenya ... my 1HZ hits 150kmh .... so I guess you need to check your injector´s tips and maybe send your pump to a Diesel Lab. ... is burning oil? no black smoke?
    let us know how it goes ... how´s the Unimog?
    regards,
  9. Tapage
    Tapage Club 4X4 Panamá SILVER Star
    23,341
    1,369
    Apr 4, 2003
    Panamá
    I thought the loss power is related to a diesel issue, not sure if is a pump issue ..
    If you haven't temp problems, are no more diesel that you can burn .. then y a loss in diesel flow. Try change the diesel filter ( I'm not sure if yoy TLC have a diesel / water separator but if check it also )
    keep up posted .. !
  10. crushers
    crushers post ho
    22,189
    206
    Feb 10, 2004
    Tara Ontario
    a naturally asperated 1HZ that hits 150 km/hr?!?! WOW!!
  11. Eric Winkworth
    Eric Winkworth
    2,091
    8
    Mar 1, 2005
    do you drive the unimog, on the road?
  12. Tapage
    23,341
    1,369
    Apr 4, 2003
    Panamá
    1HZ in good shape with 31" stock tires and no lift why not .. ?
  13. -uhuru-
    -uhuru-
    197
    Media:
    3
    9
    Aug 9, 2005
    Panama
    and she keeps going if I don't stop her man ... with M/T 31's .... the previous owner said he had hit the speedometer all the way to the max @ 180 KM/H ... I believe him since he had 31" road friendly A/T's on it and only 30,000 km on the ODO... this is on a HJ70 by the way not an 80 ... the 70 with the N/A HZ, stock gearing, and a manual tranny is way faster than my 80 with a 1HD-T , 4.88's and auto tranny ... I guess it is weight related ...
