Power Brake Booster H engine
Northern Colorado
Looking at upgrading the brakes on my 74 HJ45. Does the H have a vacuum pump? I didn't see anything like that...just wondering what my options are. I know there are electric units...just wondering what my options are...
Thanks from the newb!
Ben
Ben
check the back of the alternator, that's where the vac pump is on the 2H. if you don't have a brake booster, and don't have a clutch booster, you probably don't have a vac pump though. maybe a later alt would bolt up?
j
j
I saw those vacuum pumps and mine doesn't have that. hmmm...I guess i should just see how used to it I am after bleeding and getting them working right.
We'll, without a booster or vacuum the pedal is going to be hard. I dunno what kind of bore that one has but you could try and upgrade to a bigger bore or find a used alt that has a vacuum pump on it and put it on and run a vacuum booster like the later models. They aren't cheap though.
This is the 2H alternator shows the vacuum pump and bracket. Hope its of some help. cheers
