The brand of Speed bleeders I used would not seat properly in the rear calipers, the front were OK. Here's a photo of three bleed screws; the original Toyota part on the left, a new Toyota replacement in the middle, and a Speed bleeder on the right. Note that the OEM bleed screws have a shorter blunted tip and the Speed bleeder has a pointed tip; that extra half millimeter prevented the Speed bleeder from seating all the way in the rear calipers only. I ended up using OEM style bleed screws for the rear calipers but probably could have just filed off the tip of the Speed bleeder and used that. Another small thing; with this Speed bleeder due to the nut part being situated lower than the Toyota bleed screw your wrench will not clear a bolt on the caliper so you make a small turn, reposition the wrench, turn some more, etc. A small socket may work better. IME the cheapo one-man bleeder bottle worked well.
Mine were the bleeders from this site. I have not tried the parts store variety, but I imagine if they aren't from the same mfg already you would at v least get the same performance. Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake BleederAre these napa speed bleeders?
I've got a pressure bleeder for my audi and our old race car but it has a screw adapter for the master res. What do you use to make it work on the 80's? / How did you make your's?
And I just made my own pressure tank from an ace hardware garden sprayer.
I have been using Motive for over 10 years for racing, when you really need to get all the fluid out and replace it nothing is easier or faster. Specially when you swap between blue and yellow fluids, easy to validate the old fluid is out.
Anyways, for the 80, the only way I was able to get a good seal is with the universal kit mentioned above, but not using the chain, it would never seal. So I use zip ties, worked every time on Toyota and Honda reservoirs.
For air that can get trapped in some ABS systems, if you can't actuate the system with a computer, then a Phoenix reverse bleeder works great. You can see bubbles coming up on the reservoir if thats the problem.
What did you use as a cap for the reservoir?
