Jim S.
How they're mounted, likes / dislikes, etc. Don't know whether to go traditional style or digital. Thanks.
Note: This feature currently requires accessing the site using the built-in Safari browser.
I have always used cheap induction style tachs on snowmobiles and dirt bikes. One cruiser I had, I stuck one in the ashtray and ran the wire through a firewall hole to the plug wire. Worked well but I didn’t have it too long. I used it for setting idle and general tuning.
Filled PO’s holes.
ok, now i'm impressed..not by the small size, which is nice, but by the 4k range..truly very nice you get to use 3/4 of the swing vs only a quarter of it
I looked around a bit for a FJ60 tach, but wasn’t successful, plus I had the two holes the PO(s) had cut into the dash to fill or … well fill. I was almost on the verge to fill them with metaland forgo the tach (and the Autometer volt meter which I already had and fit - 2-1/16”) when I came across the speedhuts. They’re the only ones I found that had a 4k gauge in 2-1/16”. 2-1/16" Tachometer 4K RPM Shift-light - https://speedhut.com/gauge-application/classic-street-rod/classic-tachometers/classic-standard-tachometer/2-1-16-tachometer-4k-rpm-shift-light/
The way I drive my cruisers, I really don’t need much over 2k.
Do you have details on the gauges in your cluster?Cheap VatoZone plastic tach clamped on the steering column. Works well for me.
Thank you. The gears in my head are starting to turn.I replaced the stock oil pressure, temperature, and ammeter gauges with Autometer equivalents, though I used a voltmeter in place of the ammeter. There is a Mud member who used to make kits to do this, and I bought and used one of his kits. Unfortunately, he is no longer making or selling the kits.
The important parts of the kit were a custom-formed sheet metal bracket that the new gauges bolted to, and a mask for the front so that the gauges looked right (more like stock) in the cluster. It also included electroluminescent wire to light the entire cluster (this was before LED cluster lights were commonly available).
Autometer, Ziptied. I like the 4k limit and it's lighted.
The straight on pic is misleading, it only blocks the blue high beam light in the gauge cluster from the drivers view.
View attachment 2920134View attachment 2920135
