Okay, so I started my head gasket replacement back in July, after months of bad weather, no time, waiting for parts, it's all back together. filled with coolant, changed the oil, did the Sequoia alternator upgrade, no parts leftover. Crossed my fingers and turned the key, it fired right up on the second crank!! turned it off, filled power steering, filled transmission back up. Started it again, beautiful oil pressure, no reading on temp gauge. Okay, turned it off, checked coolant level, radiator is full, I put 2 and 2/3's gallons of Peak red/pink for Toyota vehicles prior to starting it. There should be enough coolant in there to run the engine. Short story Long,... I went to start it again, it wouldn't crank. I haven't checked the fusible link yet, but I'm hoping that is the culprit. I hooked up an OBD II reader, says, EGR, O2, and 2 others, (one looks like either HTR or MTR, can't tell). SO.......My question, if not the fusible link, what other areas should I be looking at? If the starter is not engaging, I'm assuming it's an electrical issue.
