Possible tranny and transfer. problems
Knoxville, Tennessee
On my '83 FJ60 when in four hi it is rather hard to shift back to 2wd if not imposible some times if i slowly let the clutch out and push it will go into 2wd. All so when i shift into reverse it grinds 80% of the time have clutch pedelt to floor with no trottle applied. Any ideas?
Poser
Oh...Durka Durka Durka.
Supporting Vendor
MN
First issue is "normal" to a point. If your driveline is bound up at all, you will not be able to move the little shifting collar. It is suggested in the owners manual to try and back up a few feet, while trying to shift the t-case from 4WD.
The second issue:
There is not a syncro on the reverse gear in your transmission. Your linkage rod on the slave cylinder could need to be lengthend a little, there is a threaded adjustment on this piece. When you see it, you will understand. Perhaps the clutch is not releasing completly when you depress the pedal. Another thing you could do, is just put the truck into second gear, and then into reverse, therby using the second gear syncro to slow the rotating gears in the trans. I would adjust the linkage first tho..
Good luck!
-Steve
