Possible Radiator/Thermostat issue?
San Diego, CA
I've noticed about 3 times now where the temperature will creep up, not into the red, but halfway from normal to hot, happened once in traffic, once while wheelin, and last night going up a hill.
it never goes to hot, just higher than normal, coming from newfangled MPFI Computer controlled cars, I'm not used to seeing fluctuations unless something is really broken.
the radiator was recently cored and flushed and the fan and clutch were replaced.
yes, the shroud is in place, that was my first assumption.
My 60 was heating up in a similar manner and I found that it was caused by a pin hole leak in the lower hose, which would leak when driving. This resulted in 'almost red' gauge readings in Arizona and Utah in Summer - HOT. Some increase in heat while driving in conditions you describe sounds normal to me.
M
were the hoses replaces when the radiator was cored and flushed? if not, definately start there. cant hurt and you can keep the old ones as backup if that is not the problem.
next least expensive thing to check is the thermostat. just go OEM and be sure to get the gasket seal and the upper rubber donut seal. as landpimp can attest to, make sure that upper seal goes in correctly. use toyota red coolant mixed with distilled water. - be careful when removing the tstat blolts, they tend to snap. and, if you have to take the shroud off again, cut it in half at the midway point. it makes getting to the fan so much easier when you can just remove the top 1/2.
if you still have a problem, replace the radiator. i got one from http://www.performanceradiator.com/ much cheaper than OEM, fit perfectly and there are many happy customers in FJ6X's.
that should do it. would be a whole new cooling system after that not needing to be touched for years to come.
I have had a similar issue when I get air into my system. Once I get it fully purged (some call it burping) then mine runs in the lower third all the time regardless of outside temps/load/etc. With some air in the system, the temp will creep up to 1/2 under high load/low speed, or during hot days in slow traffic.
Just recently I noticed my temp was starting to creep up again, and also noticed that my overflow bottle was getting fuller. Turns out my rad cap was letting coolant out and air back in. Replaced the cap, and now I'm stable at 1/3 again.
Could also be normal. Engine starts to heat up and fan clutch comes on to cool things down again. Your old fan clutch may have been either free-wheeling (doing nothing) or stuck on all the time (resulting in overcooling, or unnessary cooling). Perhaps you are just getting used to the normal fluctuations. Same thing happened to me, at least, when I replaced my bad fan clutch...
Tim
88 fj62 TLCA
If you're switching to Toy. red coolant, be sure and THOROUGHLY clean out the old green stuff...mixing the two can cause scum and clogging and you don't want that.
