- Joined
- Mar 3, 2015
- Threads
- 70
- Messages
- 382
- Location
- Lonely Nevada
- Website
- www.willenosphotography.com
Recently I got an oil sample result back that shows excessive wear. Chromium.. iron.. copper.. etc. Pretty much discounted it. Talked to Blackstone and they admit it could have been mixed up with someone else.. but highly unlikely. The LC has 109,000 miles.. sounds perfect.. gets standard MPG and only burned about a quart of oil in 5,000 miles. When I changed the oil at 5,000 it was fairly clean still. Not a candidate in my mind for excessive internal wear.
Installed a VDO oil pressure gauge.. just because I like them and the OEM gauge tells me nothing. Besides if pressure is low.. I really want to know NOW. So the results after driving it for enough time to get those numbers has me a bit worried that there is a problem.
50 degree day.. 185 degrees for the coolant. At idle I am under 5 psi.. guessing probably 3 and change. At 3,000 rpm 39psi. As is probably known by others.. FSM = 3.9 psi at idle and 36-71 psi at 3,000 rpm. I got a solid 40 out of it at about 3,300. This is with Mobil One 10w-30. Wix XP filter. Zero miles on a fresh change.
I certainly don't like hanging out at the low end of the spec. SO do I need to dig into this and get the pressure up and inspect main bearings. Or are the psi numbers I have good and I am just being silly. The other side would be that the Blackstone sample was not mixed up and I am looking at a full rebuild if I don't get the PSI up and soon. Maybe looking at a rebuild anyway.. especially if a compression and leak down indicate it is so. Head gasket is solid. No coolant or other particulates that would indicate a loss of sealing.
Opinions asked for and appreciated!!
