- Location
- United States
The time has come. I have decided to part with my 100-series Toyota Land Cruiser.
Asking $18,000 OBO
I have owned this one for a little over a year after buying it from the original owner. I'm driving a lot more now and just need to move into something a little more economical - or a 200 series
The AHC works great and is fully functioning.
In that time, I’ve really enjoyed driving this thing. I’ve kept up with the maintenance and done a few fun things as well.
• I removed the rear mud flaps and replace them with block off plates to give the rear a little better clearance and much better appearance. I still have the mud flaps and they and the truck are unmolested and could easily be reinstalled.
• I removed the running board and weird passenger side weight thing and still have them in their original, unmolested version and can be easily reinstalled.
• I added the Japan 4x4 shock spacers, adjusted the AHC sensors, added the King springs designed for AHC, and tightened the torsion bars to give the truck about 2” lift. AHC pressures were kept in spec and can be validated through Techstream.
• Replaced the OEM sized tires with 275/70R18 General Grabber ATx.
• Added a tape deck mount to allow for a RAM mount for my iPad. The tape deck mount goes with the truck but I’ll be keeping the RAM accessories. I have the original tape deck pieces and these can be reinstalled for a fully functioning tape deck.
• Weathertech floor and cargo mats. I have the original carpet. The cargo mat will only work when the third row seats are removed.
Maintenance:
Mileage Date Description
197950 6/25/2019 Reboot UBJs
197475 6/16/2019 Replace front stabilizer bar links
197450 6/14/2019 Replace passenger side CV axle
197323 6/06/2019 Oil change w/ Mobil 1 synthetic 5W-30
186257 9/12/2018 Oil change w/ Mobil 1 synthetic 5W-30
182000 5/23/2018 Coolant flush with SLLC from Toyota
182000 5/23/2018 Replace both heater tees with OEM
182000 5/23/2018 Replace radiator with Denso
180118 4/16/2018 Oil change 5W-30 Synthetic
177506 11/17/2017 Replace timing belt
174416 06/28/2017 Oil change 5W-30 Synthetic
169829 10/25/2016 Oil change 5W-30 Synthetic
169829 10/25/2016 Transmission fluid flush
169829 10/25/2016 flush brake with DOT3
169829 10/25/2016 Clean blower motor
167240 08/15/2016 Oil change 5W-30 Synthetic
162270 08/15/2016 Oil change 5W-30 Synthetic
157986 12/21/2015 Oil change 5W-30 Synthetic
157986 12/21/2015 Replace Spark Plugs - Denso Iridium
157986 12/21/2015 Replace Fuel Filter
157986 12/21/2015 Machine Rear Rotors
157986 12/21/2015 Replace Rear Brake Pads
152741 Oil change 5W-30 Synthetic
152741 Replace Air Filter
152741 Flush Power Steering System
152741 Cooling system flush - Toyota Pink
152741 Transfer case service
152741 Rear diff service
146845 Oil change 5W-30 Synthetic
146845 Replace Oil Pan Gasket
146845 Replace Crankshaft Seal
146845 Replace Rear Main Seal using split type neoprene seal
140000 01/27/2015 Oil change 5W-30 Synthetic
140000 01/27/2015 Replace front axles/CV boots
140000 01/27/2015 Replace front shock absorbers
140000 01/27/2015 Replace rear shock absorbers
140000 01/27/2015 Replace Evap Control Canister
140000 01/27/2015 Alignment
140000 01/27/2015 Replace gas cap
140000 01/27/2015 Replace AHC Fluid
136203 Oil change 5W-30 Synthetic
130751 Oil change 5W-30 Synthetic
126044 Repack front wheel bearings
126044 Replace Front Rotors
126044 Replace Front Brake Pads
126044 Machine Rear Rotors
126044 Replace Rear Brake Pads
126044 flush brake with DOT3
125129 Oil change 5W-30 Synthetic
125129 Replace Air Filter
121722 Oil change 5W-30 Synthetic
116458 Oil change 5W-30 Synthetic
112515 Oil change 5W-30 Synthetic
107467 Oil change 5W-30 Synthetic
102332 Oil change 5W-30 Synthetic
102332 Machine Front Rotors
97051 Oil change 5W-30 Synthetic
97051 Replace timing belt
97051 Cooling system flush
97051 Transmission fluid flush
97051 Replace Air Filter
97051 Cabin Air Filter replacement
91853 Oil change 5W-30 Synthetic
91853 Machine Front Rotors
91853 Replace Front Brake Pads
88388 Oil change 5W-30 Synthetic
83141 Oil change 5W-30 Synthetic
78769 Oil change 5W-30 Synthetic
75484 Replace Rear Rotors
75484 Replace Rear Brake Pads
73415 Oil change 5W-30 Synthetic
69046 Oil change 5W-30 Synthetic
63853 Oil change 5W-30 Synthetic
63853 60000 mile service/inspection
63853 Front diff service
63853 Transfer case service
63853 Rear diff service
58152 02/19/2010 replace front rotors
58152 02/20/2010 replace front brake pads
58152 02/21/2010 flush brake with DOT3
58152 02/22/2010 Oil change 5W-30 Synthetic
57127 Oil change 5W-30 Synthetic
51859 Oil change 5W-30 Synthetic
41172 04/09/2009 Oil change 5W-30 Synthetic
35387 01/09/2009 flush brake with DOT3
35387 01/09/2009 Transmission fluid flush
35387 01/09/2009 Cooling system flush
35387 01/09/2009 Fuel injector service
34015 12/31/2008 Oil change 5W-30 Synthetic
34015 12/31/2008 Replace Alternator Belt
34015 12/31/2008 Replace Front Rotors
34015 12/31/2008 Replace Front Brake Pads
VIN: JTEHT05J672115207
Asking $18,000 OBO
Maintenance:
