may need to revamp some lines coming out of the wall for optimized arrangement.
I would like to cut them pretty close to the wall and use a compression ball valve or union there because unsure about sweating it in so close to the wall (sheetrock under plaster?) with unknown things touching the copper pipe in there, so thinking compression.
But don't want to do that if the compression fitting (I mean one of those "ring" types) is likely to leak at some point.
How good are these fittings? As leakproof as sweated copper fittings? And this is a one-time shot, right?
