pls identify dizzy - need to order cap/rotor (1 Viewer)
Iowa
can someone please tell me the years application for this dizzy so I can get a new cap and rotor? thanks
i have an extra cap in my accumulated parts pile but it is smaller... this seems to be the approx diameter of a stock one on a 79 I have but is obviously points and is held down with the two pictured clips (vs three bolts on the 79)
looking for years used please
It looks like the 77 I just put in a 72.
What is the part number on the side sticker?
if you poast clear up close photos of the original NIPPONDENSO FOIL colored decal on side of your unit
exactly like @pjohnson has on display perfectly i must say ! :cool:
i can then give you a EXACT production date code and exact toyota parts numbers OEM you need
NO guesswork hre my friend , ONLY concrete info required
foil on this one is partially unreadable - can only see 19100- on green foil
found another dizzy laying around that matches size, this one is black foil label 19100-60080
appreciate knowing years for this one @ToyotaMatt
thanks!
thanks!
this 60080 goes back OLDER then 1969 .........fyi
i would say at least 1965-66 maybe older ?
- This Is a SMall Cap unit .......
19101CAP SUB-ASSY, DISTRIBUTOR
19101-41010
19102ROTOR SUB-ASSY, DISTRIBUTOR
19102-41010
19901CORD SET, COIL & SPARK, W/RESISTIVE
90919-21017
Part 19100-60080 (DISTRIBUTOR ASSY) was found on the following models:
MarketDate rangeModelFrames/OptionsFound in diagram
N. America03/1969-06/1980Land Cruiser USA-Spec. BJ40,FJ4*,5519-02: DISTRIBUTOR
Model Dates:Matching Models:Model Options:Links to diagrams:
03/1969-12/1974FJ40L-A
03/1969-12/1974FJ40LV-A
04/1972-12/1974FJ40LV-AC
03/1969-12/1974FJ55LG
Mine has a green label also, same first set of numbers. You seem to have the same dist I posted a picture of. I would go with 1977.
Here's another pic.
Also, you are missing the condenser.in your pic.
No condenser on the stock '77 2F ignition, it uses an igniter. But if you don't have an igniter an external condenser mounted to the distributor housing will serve a similar function - to extend the life of your points.
Doh! Yeah, I forgot that I did not use an igniter for the one I installed.
Thanks @4Cruisers for the correction.
