Hmm.....so this is a rear only problem?Thank you but mine is an 08
Yeah, rear only mainly on passenger side. Are you able to see the tech stream photo I attached I feel like the thing highlighted could be the issueHmm.....so this is a rear only problem?
Hello,
I've been having weird symptoms from the HVAC system where certain vents would blow air and others would not work, other times top vents would blow frigid air while the bottom ones would blow lukewarm air. I hooked up Techstream and got the following data, I'm assuming the estimated temp (rear D side) & estimated temp (rear P side) would be the culprits are the numbers are way off, but would appreciate any input/insight on where to diagnose and what to change.
Front seats A/C & heat work fine.
Thanks!
