- Joined
- Dec 24, 2003
- Threads
- 136
- Messages
- 3,559
Fine folks, I need some help understanding something. I was thinking of insulating some walls with reflectix reflective insulation and saw something that made me wonder if my method would work well or not. I wanted to staple between studs and up against the inside of our plywood sheathing of our house the reflectix reflective insulation and then put the standard fiberglass batting between the studs and on top of the reflectix reflective stuff. I'm not understanding whether that works with the definition detailed below about air space requirements. Would a fiberglass batt qualify as an air space in itself or not? If not it seems somewhat unrealistic to maintain a physical separation btwn the fiberglass and the reflectix; even furring strips would allow some settling pushing the fiberglass up against the reflectix. I'm just not getting it on my own so any advice would be wonderful. Thanks.
This is from the reflectix site:
Why are Air Spaces Required (in every application)?
For either a reflective insulation or a radiant barrier, an air space of a minimum thickness is required on the reflective (shiny) side of the product. The reflective insulation benefit is derived from the interaction of the highly reflective surface with the air space. If the reflective surface is in contact with another building material, it becomes a conductor (transmitting the energy by conduction). An air space may be specified on one or both sides of the product (always on a reflective side). Enclosed air spaces, when instructed, are required to provide the stated R-value.
