NeverGiveUpYota
Dare me.
Seeking assistance '87 FJ60.... I rebuilt a Aisin carb. I verified the linkages are correct per SOR's website pixs and my own stock carb sitting next to it plus had emailed few pixs to JimC. I also replaced the secondary diaphragm as well and replaced the rod with the correct per JimC verifying via PM. Also replaced the accelerator plunger with the OEM from Toyota and soaked prior to install. New cap, rotor, plugs and wires have been added as well.
As well as updated vacuum lines with new. My truck ran prior tho had some hesitation around 1800rpms hence the rebuild. My truck was also one of the many heavily molested desmoged victims out there. I have since added a VCV at diz side, as well as an HAC and have the AC idle and fuel decel included as well.
I am still w/o a VCV2 on drivers side as well as a T on PCV for line to diz VCV.
My problem in concern is: She won't hold an idle. And at a full choke will roar to 3k, sounds like a friggen jet plane. But peters out at 1/4 choke w/ rpms about 1k. I have set the idle mix per FSM in full then out three turns. I have played with the idle speed screw and fast idle (mistakenly thought it was the idle speed initially).
I am posting pictures of my lines, bear with me and please tell me if I am correct so far.... Will add in few minutes via my ph.
I live in CT, so not dealing with much elevation. Should HAC even be hooked up? And if I don't get a VCV2 for drivers side what then with the ports that would go to it? Cap?
