Pitman Arm Seal (1 Viewer)
rcb
Savannah, GA Area
I'm replacing the pitman arm seal on my 73 manual steering box. I went to Advanced Auto and the one I got from them is the wrong one. I was wondering if anyone knows the part number for this seal so i might be able to cross reference it.
Thanks,
R.C.
PabloCruise said:
I don't remember part number, but your Toyota dealer will hook you up.
Cruiser Dan will probably hook you up even faster!
I second that about Cruiser Dan. I just got the same seal for a 79 Power steering box.
Dan called it a Sector shaft seal.
Did you get your pitman arm off yet? I had a hell of a time and broke 2 pullers.
Kevin
Koyo- CR number MH8 or s 3244 8 or 9 or s can't tell for sure. I'd first try MH8A 32 44 9 best I can do.
Thanks alot for the numbers. I'll see what napa can come up with. I got the pitman arm off. first i tried a puller and it kept wanting slip off. so i heated it up and made it a bit smaller and then had to heat the pitman arm up til it was nearly red and the used the puller with an impact gun.
When i did mine i had to use the toyota seal the napa seal wouldn't find the box. I have had a lot of problems with aftermarket seals not fitting.
mike
