I upgraded my 74 Fj40 to power steering and installed a 79 FJ40 power steering box. Everything is working fine but I have a fluid leak at the pitman arm. Got a seal from CruiserDan and went to pull my pitman arm today, It won't move. The nut and washer came off fine but I've broken 2 gear pullers and went to Sears and bought the largest one they had and tightened it with a breaker bar till I couldn't move it and still no go. I'm afaid I'll have a pin shear on the puller and it will shoot through my fender. I heated the arm as much as I could without burning up the PS box. If I knew if the arm was the same as the manual arm I might split the arm off the shaft with a cutting wheel. Any sugestions?
Thanks
Kevin
Thanks
Kevin
