Pionner P12 chain saw
Stockton, CA
I found this old saw in the trash at work, So the first thing that came to mind was to pull it out and see if I can save it.
Sweet!
That is from the mid 1970's. Wright used to make that saw for a few different companies.
Unless anything is missing, fuel lines, fule filter and a carb kit and it should be good to go. If anything more than that you may have to reaseal the crankcase and maybe cransshaft seals since they may be dried out.
I got it cleaned up Put some fuel in it and it started on the first pull:lol: It ran for a few sec, then it died so drained then fuel out filled it up then drained it again then refilled. Pulled the cord it sputtered for a few then came to life, I adjusted the chain and called it good:D Went out side to cut me some wood a couple 2x4 latter I have myself a new Xmas tree cutter:beer:
